Regarding an issue with flow designer
Santhosh15
I am facing the issue with variable value, when i am trying to create the catalog task based on existing variable value its taking the default value already selected in existing value. its not taking the new variable value.
Suppose when i submit a request with variable value is no, then i am trying to change in catalog task has "yes" still the flow is assigning as "no". then other catalog task is no creating.
Could anyone for us please provide the solution for this issue.
Advance in Thanks
Shruti
To fetch the latest variable value, use look up record action
Santhosh15
@Shruti  , Could you please provide some example
Can you please share screenshot of the flow?
