Regarding Proactive Problem Management
rohan_dh
I have a question related to Proactive Problem Management. It's mentioned in the ServiceNow documentation, that a proactive problem record is opened via incident trend analysis, event management, CMDB etc.
In case, a new problem record is opened directly from an Incident, it's considered as a Reactive Problem record and if a new problem record is opened directly from the SOW / classic backend, it's considered as Proactive.
I have 3 questions related to this:
1. Is there any way where there's a field called "Proactive" which can be included, while creating the Problem Record? If yes, where can I find it?
2.  If there's no option as mentioned in Question 1, How can we configure a radio button / checkbox, which can be checked, in case anyone wants to open a Proactive problem record? So that it will be clearly visible to the team, that this problem record is proactive.
3. While doing reporting / performance analytics, how can we differentiate, a problem record as Proactive and Reactive?
jaan
Did you got an solution for your question?
