Release Management Workflow Documentation?
Stacy1
Mega Guru
Does anyone have a document that shows the workflow of how Release Management works?   I have not worked with Business Rules for workflows and having a visual chart diagram of how the process works would be helpful in our setup.
Thank you in advance.
Stacy
There is no workflow it's all business rule driven.
I ended up designing my own business rules and flows and do not use the OOTB options.
Sorry that is not very helpful.
thanks,
Stacy
kiranbahl27
Hi Stacy
Did you figure this out? Can you please help me?
I would greatly appreciate your help with this if possible. I’m stuck  I don’t know where to start for release management I know there’s no workflow tied to it I need to know two things where can I add approval and also I need some release task automatically created I don’t know where to do that. Ant help would be apprciated
thanks,
Stacy
