02-27-2025 01:26 AM
Hi Team,
We used "GlideDialogWindow" in a UI Page and Client script to fetch values of fields from a dialog box. But we recently started facing issue with all these fields on the dialog box. These fields no more capture any value and store in the table. We suspect it is because "GlideDialogWindow" is deprecated in ServiceNow. We tried to use "GlideModal" API but it is not getting defined in the system. Can someone help us know how to use "GlideModal" in Servicenow as we are unable to replace it and fix the the issue.
Thank you in advance!
02-28-2025 03:15 AM
Did my response worked for the UI page logic?
I believe your original question was to replace GlideDialog with GlideModal and you were not able to achieve it.
I provided answer to it.
Next part you can debug from your side why the update is not allowed.
02-28-2025 03:29 AM
the OOB business rule is getting satisfied during the update and blocking
please debug the business rule
02-27-2025 02:39 AM
@Ankur Bawiskar , Please find the html code below:
<g:ui_form>
<table>
<tr>
<td style="width:60%">
<input type="text" name="my_qcpc_notes" id="my_qcpc_notes" table="sn_hr_core_case" mandatory="true" field="u_qcpc_qcpc_notes" query="active=true"/>
</td>
</tr>
<tr>
<td>
<g:dialog_buttons_ok_cancel ok_id="submitData" ok="return continueOK()" ok_type="button" ok_text="${gs.getMessage('Ok')}" ok_style_class="btn btn-primary" cancel_type="button" cancel_id="cancelData" cancel_style_class="btn btn-default" cancel="return continueCancel()"/>
</td>
</tr>
</table>
</g:ui_form>
</j:jelly>
This was working completely fine before. We were using this since 2021 and we started facing issue from Jan 2025. Our instance is upgraded to Patch 9 Washington version and not sure if this is the issue.
Additionaly, when we are trying to submit the value on the form it started throwing an error
02-27-2025 02:49 AM
just because it's deprecated it doesn't mean it should be replaced, that's not what they should respond.
there are lot of OOB UI Actions where you will find GlideModal and how the value is passed from UI action to UI page
How do I pass values to UI Page with glideModal?
02-27-2025 02:55 AM
try this
Client script:
if (g_form.getValue('u_qcpc') == 'Escape' || g_form.getValue('u_qcpc') == 'Turnback') {
var dialog = new GlideModal('sn_hr_core_QCPC Dialog');
dialog.setTitle('QCPC Dialog'); //Set the dialog title
dialog.setSize(500, 5000); //Set the dialog size
// dialog.setPreference('my_source', g_form.getUniqueValue()); //pass current object id
// dialog.setPreference('value', newValue); //pass the selected value on the form
dialog.setPreference('case_no', g_form.getValue("number"));
dialog.render(); //Open the dialog
UI Page
Client Script:
function continueOK() {
var not = gel('my_qcpc_notes').value;
if (not == "") {
alert("Please enter QCPC Notes");
return false;
var hrcase_no = GlideModal.prototype.get('case_no');
var record = new GlideRecord('sn_hr_core_case');
record.addQuery('number', hrcase_no);
record.query();
if (record.next()) {
record.u_qcpc_qcpc_notes = not;
record.update();
GlideDialogWindow.get().destroy();
02-27-2025 02:28 AM
02-27-2025 03:11 AM
I tried the scripts. The error stopped showing up but the field still didn't capture any value. One thing I observed while using GlideModal is it's not getting defined in the scripts. Please find the attached screenshot. There is a difference when we call GlideDialogWindow and GlideModal. Why is this happening this way. Is this the reason why the scripts are not working. Am I missing something? Please help me understand this.
