02-27-2025 01:26 AM
Hi Team,
We used "GlideDialogWindow" in a UI Page and Client script to fetch values of fields from a dialog box. But we recently started facing issue with all these fields on the dialog box. These fields no more capture any value and store in the table. We suspect it is because "GlideDialogWindow" is deprecated in ServiceNow. We tried to use "GlideModal" API but it is not getting defined in the system. Can someone help us know how to use "GlideModal" in Servicenow as we are unable to replace it and fix the the issue.
Thank you in advance!
02-28-2025 03:15 AM
Did my response worked for the UI page logic?
I believe your original question was to replace GlideDialog with GlideModal and you were not able to achieve it.
I provided answer to it.
Next part you can debug from your side why the update is not allowed.
02-28-2025 03:29 AM
the OOB business rule is getting satisfied during the update and blocking
please debug the business rule
02-27-2025 03:16 AM
check any OOB UI page in scoped app which uses GlideModal and how it's passing the parameter value using setPreference
02-27-2025 11:35 PM
Hope you are doing good.
02-27-2025 11:43 PM
Hi @Ankur Bawiskar ,
I checked all OOB Scripts and changed the scripts accordingly but the issue is still there. I added logs and found that the script is breaking at the below line:
var hrcase_no = GlideModal.prototype.get('case_no');It is not fetching the value from client script to UI Page. Can you please help on this.
Thank you!
02-28-2025 12:00 AM
I was able to pass value and get using this syntax
So please do this
HTML:
<g:ui_form>
<g:evaluate var="sysparm_number" expression="RP.getWindowProperties().case_no"/>
<input type="hidden" id="casenumber" value="${sysparm_number}"/>
<table>
<tr>
<td style="width:60%">
<input type="text" name="my_qcpc_notes" id="my_qcpc_notes" table="sn_hr_core_case" mandatory="true" field="u_qcpc_qcpc_notes" query="active=true"/>
</td>
</tr>
<tr>
<td>
<g:dialog_buttons_ok_cancel ok_id="submitData" ok="return continueOK()" ok_type="button" ok_text="${gs.getMessage('Ok')}" ok_style_class="btn btn-primary" cancel_type="button" cancel_id="cancelData" cancel_style_class="btn btn-default" cancel="return continueCancel()"/>
</td>
</tr>
</table>
</g:ui_form>
</j:jelly>
Client Script:
function continueOK() {
var not = gel('my_qcpc_notes').value;
if (not == "") {
alert("Please enter QCPC Notes");
return false;
var hrcase_no = gel('casenumber').value;
var record = new GlideRecord('sn_hr_core_case');
record.addQuery('number', hrcase_no);
record.query();
if (record.next()) {
record.u_qcpc_qcpc_notes = not;
record.update();
GlideDialogWindow.get().destroy();
Working Solution: I got the case number in HTML side and the same can be accessed in client script
02-28-2025 02:52 AM
Now it's showing the error again. The error says "Selected document template has an incompatible document template category specified." which is coming from "Doc template and category validation" OOB BR. Not sure why this script is aborting the action on the UI Page.
