Request for employee number is populate
dgarad
Tera Sage
The request for the employee number is populated I want to populate the user name.
If my answer finds you well, helpful, and related to the question asked. Please mark it as correct and helpful.
dgarad
2 ACCEPTED SOLUTIONS
piyushsain
Hi @dgarad
You have to go to User name field dictionary in User table and update the display as true
Piyush Sain
Hi @dgarad ,
Go to your table & change the display value of number field to false & make the field which displays user value as true.
Danish
Hi @dgarad ,
Danish
SANDEEP28
@dgarad You can make use of OOB  "Auto populate" functionality to auto populate the value if one field based on the other reference field. You don't have have to do any scripting here. Refer my solution in below thread
https://www.servicenow.com/community/developer-forum/replicate-the-choice-list-of-choice-filed-from-...
Mark Roethof
Hi there,
What is the display value for Employee? Looks like that's the Employee Number? You could consider changing the display value or if that's way too much for just this use case, you would need to change the Variable Type.
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
piyushsain
Hi @dgarad
Piyush Sain
