Require help in Client script
Yogita11_
Hello All,
I'm trying an addition script for one of my requirements. The script below automatically adds the previous and new values when the user enters "+integer_value" . However, when a user enters + and nothing, it saves the value "NaN". I attempted to stop this by using the if condition when the total sum is "NaN" then do not update. However, it does not identify the "NaN" and it always go in the script.
Is anyone dying?
    var amount = newValue.indexOf("+");
    if (amount != '-1') {
        var total_length = newValue.toString();
        var last_idex = total_length.length;
        var additioan = newValue.slice(amount + 1, last_idex);
        var convert = parseFloat(additioan, 10);
        var previous_amount = parseFloat(oldValue, 10);
        var Total_amount = parseFloat(convert) + parseFloat(previous_amount);
        if (Total_amount != "NaN") {
                  g_form.setValue('u_ec_defense_counsel_fees_string_field', Total_amount);
Brad Bowman
Mega Patron
It looks like you could only run the rest of the script if newValue != +
    if (newValue != '+') {
Brad Bowman
Mega Patron
