Reset Problem to OOB
Stuart Tucker
Is it possible to completely reset the Problem module to the out of the box functionality?
Accept the risk of lost data and information if fields are different.
Maik Skoddow
Hi @Stuart Tucker
you can try to repair it. Open the plugin page and click on the respective in the Related Links section
Kind regards
Maik
Stuart Tucker
This doesn't work. In the end I got a reply from Now Support:
There is, unfortunately, no easy way to reset a module to the Out of the Box (OOB) version.
There is no specific functionality built in to revert an entire application in a ServiceNow instance. Activating the plugin again will not revert back to base code as the customized records will still be skipped.
We do have documentation on reverting customizations which will help describe the process needed to be taken.
Revert customization:
https://docs.servicenow.com/csh?topicname=revert-customization.html&version=latest
Another available method to accomplish this is by the Update Versions table (sys_update_version). From here, the name of the record or artifact can be searched in the Name column. This will list the current version of the record and previous versions. Find the version you would like to revert to and open the record. There is an available UI action 'Revert to this version' which can be used to revert to the version selected.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0779333
https://docs.servicenow.com/bundle/sandiego-platform-administration/page/customer-support/task/revert-customization.html
If you need to speak to someone, please use one of the contact numbers from our Support contact page:
http://www.servicenow.com/support/contact-support.html You will then be able to enter your case or Change number over the phone to have your call routed to the engineer that owns that case or Change.
