Restrict Drop Down Choices Based on Assignment Group
kevinthury
We have a goal of restricting a new drop-down list on the Incident form based on what is selected for the Assignment group.
In my Personal Instance, I created a field of ‘Assignment Group Detail’ (type=string) with a number of choices.  I modeled the functionality after the Category/Subcategory list in that I added set the ‘Dependent on field’ to Assignment Group and the Choice dependent value to a Group name.
This failed to offer any values.  I tried to change the Dependent value to the sys_id of the group, and that failed as well.
The only way I was able to get this to work is by creating an OnChange Client Script that would copy the value of the Assignment Group field to another string field.  I then changed the Dependency to that new field and the drop down was properly constrained by the Assignment group choice.
While this is producing the desired results, I am questioning the efficiency.  Is there a way I can get the same results by having the Dependent field be Assignment Group and bypass the need to copy the value?
Chuck Tomasi
I haven't mixed dependent field types before and don't know if it supported. I've done choice-to-choice like category and subcategory and I've done reference to reference (assigned to and assignment group). Because a choice field is effectively a string, copying your value to another string field seems to make sense.
You could try making your detail field a reference and move the choices to a new table for the bespoke choices. Then try making your detail field dependent on the assignment group field (ref-to-ref).
Marking Chuck's answer as correct as this method allowed us the most flexibility in using across multiple forms apart from incident.
Steps Taken to Resolve:
1.  Created a new Table to house the data
2.  Created a column on the TASK table referencing the newly created table and added dependent field value (in my case...assignment_group)
3.  Added the newly created column to the Incident form and configured.  (New column can also be added to other forms as needed.)
Max C1
Giga Contributor
I did a client script to display different category options based on assignment group and another to load the correct subcategory dependents. This wouldn't work for you?
