Restrict spaces in IP address
Ankita9793
Hi All
Can someone please help with below script, how can I validate whenever user enters spaces(beginning, end, inbetween) in the string. Should not allow user to enter spaces.
    var ipAddresses = g_form.getValue('enter_ip_addresses');
    var ipList = (ipAddresses || '').replaceAll(/\s/g, '').split(',');
    var ipRegex = /^(([0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5])\.){3}([0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5])$/;
    if (ipList.length > 30) {
        g_form.clearValue('enter_ip_addresses');
        g_form.showFieldMsg('enter_ip_addresses', 'Maximum 30 IP addresses are allowed', 'info');
    ipList.some(function (item) {
        if (!ipRegex.test(item)) {
            g_form.showFieldMsg('enter_ip_addresses', 'Please enter valid IP addresses', 'info');
            return true;
Sohithanjan G
Hi @Ankita9793 ,
To prevent users from entering spaces in the string, you can modify the onChange function to validate the input for spaces. Here's how you can adjust the script:
    // Check for spaces in the string
    if (ipAddresses.trim() !== ipAddresses) {
        g_form.showFieldMsg('enter_ip_addresses', 'Spaces are not allowed in the input', 'error');
    // Rest of your validation logic goes here
    var ipList = (ipAddresses || '').split(',');
            return true;
In this modified script:
  • I've added a check to verify if there are any spaces in the input string using trim().
  • If spaces are found, an error message is displayed, and the input field is cleared.
  • The rest of the validation logic for IP addresses remains unchanged.
This modification ensures that the script checks for spaces in the input string and prevents users from entering spaces in the enter_ip_addresses field.
Please mark my answer as Accepted as Solution & hit helpful if it suffices your requirement !!!
Please mark as Accepted Solution if this solves your query and HIT Helpful if you find my answer helped you. This will help other community mates too..:)
Hi @Ankita9793 ,
Did you look at my solution
Hi Sohithanjan,
I replied to your post earlier today, not sure why I'm not able to see it.
But in case it was not posted due to some issue, here is my response.
Thank you for your response!! but the solution did not work for me, it was accepting the spaces.
I tried the below logic instead which is working fine for spaces in-between IP addresses but does not throw error for spaces in the beginning of the IP address. If you can please suggest something for that.
    alert(ipAddresses);
   // var ipList = (ipAddresses || '').replaceAll(/\s/g, '').split(',');
    //var nospaces = ipAddresses.map(String.trim);
    //alert(+ nospaces);
    //alert('IPadd and IPadd trim' + ipAddresses  +ipAddresses.trim());
    var spacetoCheckreg = /\s/;
    if(spacetoCheckreg.test(ipAddresses)){
                    //g_form.triggerErrorChangeFieldSet('Please enter valid IP addresses');
                    return true;
    ipList.some(function(item) {
                if ((!ipRegex.test(item))) {
                    return true;
Harish Bainsla
Hi try below code
// Check if the input contains spaces
if (newValue.trim().includes(' ')) {
var ipList = (ipAddresses || '').split(',').map(ip => ip.trim()); // Trim each IP to remove leading/trailing spaces
for (var i = 0; i < ipList.length; i++) {
if (!ipRegex.test(ipList[i])) {
