Restrict Variable Formatter to be editable only for certain group for a catalog item
Appu2
Hi, I need help with restricting the Variable formatter for certain group for one of the Catalog Item. My requirement is to make the Variable Formatter to be editable only for certain members of the group for rest all others it shouldn't be editable. I need to achieve this via Catalog Client Script. After submitting the request, in the backend Variables should be only editable for certain group and others shouldn't be able to edit.
Any inputs here?
Follow the below steps.
1. Write display BR on req item table
Condition : item is "select catalog name"
Script:
g_scratchpad.grp = gs.getUser().isMemberOf('ACME Support'); // pass the group name
2. Write onload client script on req item table
if(g_scratchpad.grp)
  g_form.setVariablesReadOnly(true);
Result:
Harish
Script:
Result:
Harish
Appu2
thank you so much this solution worked for me.
Appu2
Also it's not restricting for anyone if I replace gs with g_form. So this seems not working
even if you use g_user.getUserID to get user ID. The isMemberOf method is a server side method cannot use in client script
Harish
