Ritm visibility using assignment group and parent group
jobin1
Hi All
Need to get the below 3 values in Query BR how it can be achieve?
1. How we can get the current logged in user assignment group and its parent group in query BR?
2.How all Ritm group and its parent group can be get from Query BR.
3. If 1 and 2 are same(both condition returns same value) then those Ritms should only visible to logged in user
    var childIds = "";
    var groups = new global.ArrayUtil().convertArray(gs.getUser().getMyGroups());
    groups = groups.toString();
	current.addEncodedQuery("assignment_group.parentIN"+groups+"^ORassignment_groupIN"+groups);
})(current, previous);
25 REPLIES 25
Murthy Ch
Hi @jobin
Do you mean that you want to show ritm's which are part of a loggedIN user groups?
Murthy
@Murthy Chintalapudi Yes and its parent group as well.
Hi @jobin
Try this in query BR:
    var a = new global.ArrayUtil().convertArray(gs.getUser().getMyGroups()); //this will return both loggedin user groups and its parent groups
    current.addQuery("assignment_group", "IN", a.toString());
(=tested)
Murthy
Murthy
@Murthy Chintalapudi You're code is working for assignment group members but when the parent group members are impersonating that time its not working. Any other changes required?
for example  "A parent" is the parent group of "A child" now members of A child are able to see only "A child" tickets that is working but all members of "A parent" also should able to see "A child" ticket as well this is not working
