Run a scheduled job for every 3 hours
Supritha3
I have a requirement to run a scheduled job for every 3 hours, how can i do it and what values should i use.
Supritha F
Hi Supritha,
yes if you want to run it every 3 hours, then day should be 0 so that it runs every 3 hours from the date and time given in the starting field.
you mention days when you want to run it during custom interval (for ex: every 2 days or 3 days)then you mention the number in the days field.
Mark the comment as a correct answer and helpful if this answers your question.
13 REPLIES 13
Supritha3
If I have to run it everyday at the interval of 3 hours what value should I give for "Days" after Repeat interval should I leave to be 0 or set it to 1?
Supritha F
When you select Periodically then Time field does not appears on form but in your case Time field is there.
Supritha3
Also there is a field called "starting" with date and time so what would the "Time" field after "Run" ideally used for?
Supritha F
As per my understanding "starting" defines This Schedule job will start from that date
Jaspal Singh
Mega Patron
Hi Supritha,
Check old wiki link that may clear all your concerns.
