SAML Response Invalid - MultiSSO
saloniahuja
On our dev instance(Istanbul) , we have enabled MultiSSO plugin
Configured IDP by importing XML
But, we are getting to logout page after login.
How can I debug this? Can someone help please ? Thanks in advance.
Saloni
vab_13
Most likely SAML Response is evaluated being invalid and you are getting to the logout page.
Enable Multi-SSO Debug.
This debug will start printing logs along with actual SAML Response XML.
The logs will confirm on why SAML Response is being invalided. If you configured by importing XML from IDP, make sure there is no trailing forward slash "/".
Validate certificate.
From Multi-SSO Properties, enable Debug:
Multiple Provider Single Sign-On - ServiceNow Wiki
This will start printing debug information.
This debug information is pretty descriptive to confirm on why SAML Response
You can leverage script from my article to see if there is a Certificate issue:
If you still run into issues, reply back with your instance name or log a call in Hi: we can assist.
Vab
Hi Vab,
Thanks for the reply. We are troubleshooting now. Debug is now enabled.
I worked with Hi Support on couple of issues, the log file they look at by logging onto the actual server: can we request for the actual log file to be sent to us?
Saloni
vab_13
np.
You dont need to contact Hi for getting the log file.
You can download it from UI itself.
Name: localhost_log.<date stamp>.txt
Thanks! I wasnt aware of this. Helpful.
Saloni
