Script Include Not Working on getrowcount
its_SumitNow
var countofrec = Class.create();
countofrec.prototype = {
    initialize: function() {
    reco: function (xyz,desc) {
        var gr = new GlideRecord("xyz");
        gs.addInfoMessage("Inside Script Include");
        gr.addQuery('short_description','CONTAINS',desc);
        gs.addInfoMessage(gr.getRowCount());
        return  gr.getRowCount();
    type: 'countofrec'
I am calling this script Include via BR, but it is not Working,Please help
3 ACCEPTED SOLUTIONS
Bhuvan
Giga Patron
@its_SumitNow
Since you are passing the values from BR, remove double quotes from table name. Correct the syntax and try, it should work
Below is sample,
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
Shruti D
Hello @its_SumitNow
Try with below updated script include:
    reco: function(tableName, desc) {
        var gr = new GlideRecord(tableName);   // use table name
        gr.addQuery('short_description', 'CONTAINS', desc);
        var count = gr.getRowCount();
        gs.addInfoMessage("Row count: " + count);
        return count;
    type: 'countofrec'
Business Rule for example:
    var recCount = new countofrec().reco('incident', current.short_description); //replace your table name
    gs.addInfoMessage("Records found: " + recCount);
})(current, previous);
Please Mark Correct ✔️ if this solves your query and also mark Helpful 👍 if you find my response worthy based on the impact.
Shruti
Chaitanya ILCR
Giga Patron
Hi @its_SumitNow ,
update your script include as this
    initialize: function() {},
    reco: function(xyz, desc) {
        var gr = new GlideRecord(xyz);
        gs.info("Inside Script Include");
        gs.info(' row count = ' + gr.getRowCount());
    type: 'countofrec'
you can call the script include like this (example table I have chosen is incident and example short_description is test)
you can replace incident with your table name and test with your short_description
var noOfRows = new countofrec().reco('incident','test')
  you can store and use the value in a variable like noOfRows
Chaitanya
Chaitanya ILCR
Giga Patron
Hi @its_SumitNow ,
    type: 'countofrec'
Chaitanya
Ankur Bawiskar
@its_SumitNow
what debugging did you do then?
1 mistake you have
