Scripted REST API POST method not inserting record into core_company table.
Devi12
Giga Guru
I have created a scripted REST API POST method to insert a record into "core_company" table from third party. When I am testing in POSTMAN and Explore REST API It is showing status message as "200". But the record is not inserting into core_company table. How can I fix thie issue?
I am attaching the script I have used, may be this is causing the issue. Can anyone suggest how can I modify below script to insert the record.
11 REPLIES 11
Hi Ankur,
Sorry for the late reply.
I am very poor at scripting.
I wanted to insert the record from peoplesoft to Servicenow core_company table.
then check these below links on Scripted REST API
Create incident with Scripted REST API
