Search for values containing a space character (starting with, containing, ends with)
hubertn
I need to report on all assets with a serial number containing 1 or more spaces anywhere in the value.
1) can wildcards be used in report and filter conditions?   e.g. * " " *
2) how would i represent the space?   escape sequence?
3) can REGEX be used in reporting?
Thanks in advance!
Ankush Agrawal
Hi Hubert
You can create a Script Include which will have a function which returns comma separated sys_ids of the desired records. Then the same function can be used as a filter in your table.
E.g: If we want to create a report on the table sys_user where field phone contains any whitespace, we can write following Script Include:
var TestFilter = Class.create();
TestFilter.prototype = {
      initialize: function() {
  getFilter: function() {
  var v = new GlideRecord('sys_user');
  v.addQuery('phone', 'CONTAINS', ' ');
  v.query();
  return v;
      type: 'TestFilter'
And then in the report, we can use following (without quotes):
'Business Phone' 'is one of' 'javascript:new TestFilter().getFilter()'
Please refer to Reference Qualifiers - ServiceNow Wiki   for further details.
Worked for me as well. thanks
wonderfully simple.  thank you
matthiasheg
Hi Adam,
what is the likely hood you replying to a 9 year old thread with a solution I need then 4 days later! Craziness but thanks a lot!
cheers,
matt
