send survey after every 10 closed incident?
ash36
I need to send incident survey on repeated interval of 10 incident closure. I tried setting the trigger condition based on Number ends with 0, but that's not a concrete solution. Has anyone done this before?
Help much appreciated, thanks !
27 REPLIES 27
Rakesh Mamidi
For exact count of 10,You write a script include like below and call the script include in the trigger business rule condition.
var checkCount = Class.create();
checkCount.prototype = {
  initialize: function() {
  this.frequency = 10;
  checkTaskCount : function()
  var lastTriggerID = this.lastSurveyTakenFor(incident,'87186844d7211100158ba6859e610378'); //Table Name and Metric type.
  if(lastTriggerID){
  inc.get(lastTriggerID);
  var closedAt = inc.closed_at;
  var incident =   new GlideRecord('incident');
  incident.addNotNullQuery('closed_at');
  incident.addQuery('closed_at','>=',closedAt);
  incident.orderByDesc('closed_at');
  incident.chooseWindow(this.frequency-1,this.frequency);
  incident.query();
  if(incident.next()){
  return true;
  else{
  return false;
  return true;
  lastSurveyTakenFor : function(tableName,metricType)
  var gr = new GlideRecord('asmt_assessment_instance');
  gr.addQuery('trigger_table',tableName);
  gr.addQuery('metric_type',metricType);
  gr.addQuery('trigger_id','!=','');
  if(gr.next())
  return gr.trigger_id;
  else
  return false ;
  type: 'checkCount'
Thanks Rakesh,
I'll test and update you. Just to confirm, if i change 'this.frequency = 10;' to 'this.frequency = 3;' , the survey will send after every 3 incidents? Also, when you say "call the script include in the trigger business rule condition.", it means the business rule that is set in the trigger condition? Right now I have this setup in my BR script:
function onAfter(){
(new sn_assessment_core.AssessmentCreation()).conditionTrigger(current, 'e127cb9adb843a00d4385540cf961987');
Do I need to remove it and just call the script Include?
Thanks in advance!!
Rakesh Mamidi
Yes, Changing frequency will do.
Don't change any thing in the script.But in BR condition call script include as new checkCount().checkTaskCount();
Hi Rakesh,
It's sending after every closed incident. Here is my trigger condition:
and here is BR:
Ashish
Rakesh Mamidi
What is the metric type you are passing in the script include? Is it same sys_id of your survey?
