Set Req state same as RITM state when the state changes in RITM with flow designer.
LakshmiNarayan7
Mega Guru
When the state field changes in RITM then, REQ state needs to be changed.
RITM States:                      REQ States :
 Open                                    Pending Approval.
 Closed Complete.                Approved, Closed Complete
 Closed Incomplete              Closed Incomplete, Closed Cancelled, Closed Rejected
 Closed Skipped                   Closed Skipped
For Approval the state changes works fine, But not for the rejection alone.
Willem
Tera Sage
Is Request and Requested Item always a one-to-one? If not, I think there is a better solution.
If it is a one-to-one your script works with a few tweaks:
Create an After Update Business rule on the Requested Item with following code:
    var request = new GlideRecord('sc_request');
    request.get(current.request)
    if (current.state == '3') {
        request.active = false; // set active to false
        request.request_state = '3'; // Set state to closed Complete
        request.update();
    else if (current.state == '4') {
        request.request_state = '4'; // Set state to closed Incomplete
        request.update();
Checked all the BR, Seems like there is something setting all the REQ to Approved.
Trying to write a BR for updating the REQ from RITM state changes.
//if (current.variables.select_one != 'Single CI Update')
var req = current.request;
var i = 0, j = 0, k = 0;
var appr, state;
var gr =new GlideRecord('sc_req_item');
gr.addQuery('request', req);
var count = gr.getRowCount();
while(gr.next())
if (gr.approval == 'approved')
i++;
if (gr.approval == 'rejected')
j++;
if (gr.approval == 'cancelled')
k++;
if (count == i && count!= 1)
RequestState('approved', 'closed_complete');
if (j == count-1 && count!= 1)
RequestState('rejected', 'closed_rejected');
if (k == count-2 && count != 2)
RequestState('Cancelled', 'closed_incomplete');
function RequestState(appr, state)
var gr1 = new GlideRecord('sc_request');
gr1.addQuery('sys_id', req);
gr1.query();
if (gr1.next())
gr1.approval = appr;
gr1.request_state = state;
gr1.update();
})(current, previous);
Approval and Rejection works fine, Need help on Cancelling.
