setting flow variable using a script
jonathangilbert
Hi All
I am trying to set a flow variable, by taking values from 2 catalog variables, but my script does not populate anything
I wish to take the 1st letter from the "First Name" variable and the whole value from the "Surname" variable, so that in the example John Smith would give a flow variable of "Jsmith"
This is the only line script I am using in the "Set Flow variable" action:-
fd_data.current.variables.first_name .substring(0,1) + fd_data.current.variables.colleagues_surname);
even if I simplify just to try and get the value from one of the variables, fd_data.current.variables.first_name; I dont get any populated value either.
What am I doing wrong?
Ankur Bawiskar
update as this
fd_data.trigger.request_item.variables.first_name.toString().substring(0,1) + fd_data.trigger.request_item.variables.colleagues_surname;
regards
Ankur Bawiskar
update as this
regards
Good Afternoon Ankur,
I have updated with your line of script and it still returns back a blank entry
This is the script entry in the flow
This is where the description should be updated with the flow variable
There are no logs against the flow variable once it has executed
Many Thanks
jonathangilbert
Hi Ankur,
I have sorted it, usign what you had supplied but also adding in the variable dun
var dun = "DUN" + fd_data.trigger.request_item.variables.colleagues_first_name.toString().substring(0,1) + fd_data.trigger.request_item.variables.colleagues_surname;
return dun;
Thank you so much for your help again
