setting reference field value
_bhishek
I have a small query .
I have one configuration item field for RITM and TASK both which is referencing to cmdb_ci table .For one catalog item i want to display one configuration item .
I tried run script in workflow with below
task.cmdb_ci="Automated Regulation";
Also i tried with Insert update BR with setting valuse of cmdb ci field to same value on RITM table .
But value is not being displayed .Please suggest me what am i missing here .Or suggest any other way to achieve this .
Thanks .
Ankur Bawiskar
For SC Task you can use this
task.setDisplayValue("cmdb_ci","Automated Regulation");
For RITM Record you can use Run Script activity in your workflow
current.setDisplayValue("cmdb_ci","Automated Regulation");
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
_bhishek
Hi Ankur,stark,
Thanks for your response .
I was using these methods earlier .But  cmdb _ci field is not being populated with this value .When I checked the list view of sc_req_item table ,I can see cmdb_ci field is updated with this value but in form view this value is not visible .In form view cmdb_ci field is blank.
Please suggest me what could be the issue .
Thanks .
it means some client script or UI policy is clearing that field on form.
please check that once.
