Setting value of reference fields using Business Rule
tyagisu
Mega Expert
Hello!
I am trying to set some fixed values in reference fields like assignment group, location, primary configuration item. Our requirement is when incident tickets are generated from Dynatrace Integration, assignment group, location and CI should have the values X,Y and Z auto set. I tried using onLoad client script to set up these values, but it didn't work as expected. The onLoad script would work only after opening the tickets, hence I thought of using Before Business Rule.
We cannot set these values in Integration script itself because of some other requirement conflicts.
Here is my script:
current.contact_type = "X";
current.location = "Y";
current.assignment_group = "Z";
current.update();
})(current, previous);
Any help would be highly appreciated!
Su
Do you have group by name Z in your sys_user_group table. Please pass the exact name of group. Write before insert/update BR.
EX: Network is a group name
current.assignment_group.setDisplayValue('Network');
9 REPLIES 9
Yes
Shweta KHAJAPUR
If you want to set it by it's name then you can make use of  below function or else you can set it by sys_id
setDisplayValue("Z");
current.assignment_group.setDisplayValue("Z"); this didn't work.
Thanks a lot!
It worked 🙂
