Show Different States on Process Flow Formatter on Change Request Form for different views
Shrey Khurana1
I have a requirement where I need to show Different stages on Change Request form based on the view selected.
On Default view I need to show the same way as it is OOOB but on other view I need to show only 3 stages i.e. New, Scheduled, Closed and Cancelled.
So, can anyone please help me how to configure different states of process flow formatter based on the view selected on form layout.
Thanks in advance.
If you have written the logic to get the view name saved on the field on form then do the below:-
Go to Process flow:-
Then Open the stages which you want to show for only specific views and apply the filter view is the name of the view:-
Please mark answer correct/helpful based on Impact.
Aditi Dwivedi1
Hi Shrey,
Have you received the solution for this ?
