Show Field Message for Catalog variable is coming in same line
Sanjay34
I have written the code to show field message for catalog variable on load on portal. After the San Diego upgrade the message is coming in the same line as variable. Please find the screenshot for the same. Using below code :
var msg = "The message which need to be displayed";
g_form.showFieldMsg('variable_name', msg, "info");
g_form.showFieldMsg('variable_name', msg);
"Self-Serve Firewall Policy Management" The request for Firewall Policy Configuration is already in place and is scheduled for
Variable name : Self-Serve Firewall Policy Management
Field message : The request for Firewall Policy Configuration is already in place and is scheduled for
Ideally the field message should in the below line as below. Help me to fix this issue.
Ankur Bawiskar
Hi Sanjay,
If you are sure it worked fine prior to upgrade and there was no script change after upgrade; raise a Hi ticket with ServiceNow.
Do share us the updates.
Hi Ankur,
I have identified like we have used hidden Rich label text variable just above the variable for which we have to show this message. If I am making active false this Rich label variable then it is show field message is coming as expected and if it is true then it is coming in the same line. Any help please...
Rich label text variable : Order Value 62
Checkbox variable order : Order Value 64 : For this we need to show field message on load.
Thanks & Regards
Sanjay
Harpreet Walia
Could you please share if there is any update wrt the issue? It seemed to be related to only checkbox variables and related messages.
