Simple Flow Designer flow not triggering on SC TASK table
HarikrishH
A simple flow designer is not triggering but when we test it by clicking on the test button it is working fine but after activating the flow its is not triggering automatically.
Table name: Sc_task( Catalog Task )
Do we need to activate any plugin's to triggering flow?
I activated the flow and Test is successful when tested.
Asad Waseem
I am also having the same issue I am using the wait for condition and after that an if condition to create the SC task in for the request but It is triggering when I run on testing but when submit the catalog item it does not work.
maroon_byte
How are you testing? From a catalog item? or manually creating catalog task in Core UI?
Sharad
