Skip approval for a requester
Salvatore Carus
While testing a Catalog Item for ordering an expensive device, the mandatory approval is being skipped for requester Andre Boer, but not for any of other requesters. Who can explain me how is possible do this?
@Salvatore Caruso
In that case I will go with the First Option that is as below:
☐There is a Business Rule, excluding Andre Boer from any approvals
Below is the ServiceNow article supporting the fact mentioned above:
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0953049
Shloke
Shloke
9 REPLIES 9
@Salvatore Caruso
Can you check on below points and confirm and can decide which is the correct answer here?
1) Navigate to User Table and search for the user as "Andre Boer". Check if manager is present for this User or not?
Also can you share screenshot of your workflow here to help you further? Generically it will be difficult to predict on what's happening in your instance.
Shloke
Shloke
@shloke04  this is a question related to the CSA exam.
Can you help me to choice one options from the list?
@Salvatore Caruso
Shloke
Shloke
Salvatore Carus
is not mentioned the workflow, the available options are:
☐There is a BR, excluding Andre Boer from any approvals
☐The manager does not a have a delegate assigned
☐The Andre Boer user account, does not have a manager specified
☐Andre Boer does not have a delegate set up in this account
☐Andre Boer is a VIP
Jai2021
Hi ,
check whether the requester has mapped with manager in sys_user table.
