Spaces between checkbox variables
seanbracebridge
Kilo Expert
Hi Folks,
I have noticed that when you put fields in between check boxes and hide them using a policy it does not render the same look as compared to check boxes without fields in between them.
The image below have fields inserted in between each checkbox. They are hidden using a UI policy. I also tried hiding via a script using setDisplay and set Visible and it still looks the same.
I was hoping it to look like the image below
Is there anyway I can do this without using any DOM or anything that would not work with the mobile interface.
rody-bjerke
Giga Guru
Anyone found a solution for this?
Best regards,
