Splitting multi line text in a Transform Script
i want to transform (source.description) data which is in this format:
1. Click Website, 2. Enter Login Information, 3. Click Login, ...."
Into an HTML field (target.u_description) in this format:
1. Click Website,
3. Click Login"
I tried this in a "Script Background" as follows and it works, I am not sure how to use it in a transform map:
var str = " 1. Click Website, 2. Enter Login Information, 3. Click Login";
var na = str.split(",");
for (var i = 0; i < na.length; i++) {
gs.print(na[i]);
Help appreciated.
jose_valle
Hi Minaz,
You might want to try using a script for the source on your transform entry with something like this.
answer = (function transformEntry(source) {
    // Add your code here
  return source.description.split(",").join("\n"); // return the value to be put into the target field
})(source);
Hope this helps.
Hi Minaz,
Does that target field have a limit? Are you able to type more than those characters into that field directly?
I tried with your exact text and it seemed to work ok for me.
You are right. It worked for me as well.
Thanks for your Help.
