Survey Management and data gathering
smcgrath44
Kilo Explorer
We are having some challenges with the Survey Management application and wanted to reach out to the community and see if we are alone or not. We want a survey sent out to each user upon resolution of a ticket. The information that we would like to get back goes well beyond the questions and answers in the survey. We would also like to get the following:
  1. Technician who resolved the ticket
  2. The Assignment Group that the resolving tech is a member of for the ticket
  3. Business Service, Category and CI information that can be reported with survey data
We on on Eureka. We have been legacy surveys and want to utilize the new survey tool that ulitize the assessment and metrics tables. Does anyone out there have a similar challenge and or solution to this? Much thanks!
Steve McGrath
ServiceNow Administrator
Harvard Business School
TrevorK
We have just implemented surveys ourselves...or assessments...or whatever you want to call them. We opt'ed to use the new survey/assessment features and not legacy surveys, even though when we went through it legacy surveys seemed much easier. Our choice was based on a suspicion that legacy surveys would not see future development, whereas assessments would.
My post below will be based on using Assessments (Survey Management module), however I can reference the Legacy Survey's if you need.
I believe we are doing everything you want to do - we are sending out an email upon resolution of a ticket. I will walk you through our steps, and let me know which numbers you want me to go into further detail:
1) Upon closure of an Incident or RITM, we determine if a survey is required. For example, we do not want to survey students and there are certain assignment groups that do not receive a survey. We use a flag on the TASK table that we fill in if a survey is required.
2) Our notifications are two-tiered. We send a normal "Your Incident has been resolved" if our "Survey Required" flag is false. This comes off the Incident table. If "Survey Required" is true, we send a notification off of the Assessment Instance table. Because the Assessment Instance has "Trigger ID" (a field that contains the sys_id of the record calling it), we use a Mail Script to lookup the associated Incident or RITM information based on the sys_id. We then send out a "Your Incident has been resolved" email similar to above, however it is from the Assessment Instance table. We include our survey specific information in it (we use some cool graphics to entice them to click on the survey) and the Incident/Task information, which is obtained through the mail script.
3) Client takes the survey, we then do a custom table to transform the results into a format that is much easier for management to handle (a table where each row contains the questions/answers, rather than the ServiceNow format of each row being a question). We have some reporting we need to do based on the results of a specific question, and this kept it the "prettiest" for management and the most functional for our user base. The table just updates upon a survey changing to "Complete". Because we have the "Trigger ID" value (which again is the sys_id of the incident/task that called it), we can reference who the analyst was that did the ticket, the business service, etc.
Just in case anything does not make sense, I have attached a screenshot of our survey invitation email. It is run off the Assessment Instance table. While we do not show the CI/Business Service/etc., I think the other fields we pull demonstrate that we can pull those fields too.
If you have any further questions, feel free to post them. Or send me a message privately/email me and I can go into it further. We personally found the new Assessment module a bit overwhelming at first and it took longer than expected to develop it into something usable. But I think our stats are at a 12% response rate, so we must be doing a good job (our research department indicates this is a good response rate for unsolicited electronic surveys).
My apologies - I realize this is a bit long but I was unsure where exactly you were looking for feedback.
43 REPLIES 43
Sure - I'll get you a response within an hour or so!
Hi Trevor,
Thank you for your survey process. We have the same requirement, would you mind sharing a little bit information? We are moving from Legacy survey to new assessment survey, so I created a new survey which contains only 2 questions and a new notification which contains 3 smiley faces. When I click on the one of smiley face it is opening the survey but I want to populate my 1st question based on the face you select.
I know that we can pass parameters through URL using UI page (assessment_take2.do) but I am not very much familiar with this scripting part. Would you mind providing the code and process?
Any help is greatly appreciated.
Nani
Passing the values through requires some customization, and a little bit of HTML knowledge. What we do is have a link behind each of our smiley faces with a parameter inside. The parameter corresponds to happy/content/sad. We created a new UI Page (you can modify the existing if you like) to accept that parameter, and then we put that value into the corresponding question through the Load event (in Client Script section). This requires DOM manipulation so you need to be familiar with that because the values in your environment will definitely be different than yours.
Your survey could be different than mine, so the code itself will not be as helpful as the process above. If I just gave you my code (there are over 1000 lines in the modified code + original code) you could spend hours and hours debugging it just because of something as simple as your scale is different. I won't do that to you, that would be too frustrating!
Let me know if you have any more questions!
Hi Trevor,
can you help me with this thread?
https://community.servicenow.com/message/1002372#1002372
Nani
yvan
Trevor,
Where did you read up on the Assessments/Survey system? It feels like there are a number of logical connections missing from the literature.
Are you you using Assessment or Survey for that example you posted?
Thanks for any help,
Yvan
