Survey Management and data gathering
smcgrath44
Kilo Explorer
We are having some challenges with the Survey Management application and wanted to reach out to the community and see if we are alone or not. We want a survey sent out to each user upon resolution of a ticket. The information that we would like to get back goes well beyond the questions and answers in the survey. We would also like to get the following:
  1. Technician who resolved the ticket
  2. The Assignment Group that the resolving tech is a member of for the ticket
  3. Business Service, Category and CI information that can be reported with survey data
We on on Eureka. We have been legacy surveys and want to utilize the new survey tool that ulitize the assessment and metrics tables. Does anyone out there have a similar challenge and or solution to this? Much thanks!
Steve McGrath
ServiceNow Administrator
Harvard Business School
TrevorK
We have just implemented surveys ourselves...or assessments...or whatever you want to call them. We opt'ed to use the new survey/assessment features and not legacy surveys, even though when we went through it legacy surveys seemed much easier. Our choice was based on a suspicion that legacy surveys would not see future development, whereas assessments would.
My post below will be based on using Assessments (Survey Management module), however I can reference the Legacy Survey's if you need.
I believe we are doing everything you want to do - we are sending out an email upon resolution of a ticket. I will walk you through our steps, and let me know which numbers you want me to go into further detail:
1) Upon closure of an Incident or RITM, we determine if a survey is required. For example, we do not want to survey students and there are certain assignment groups that do not receive a survey. We use a flag on the TASK table that we fill in if a survey is required.
2) Our notifications are two-tiered. We send a normal "Your Incident has been resolved" if our "Survey Required" flag is false. This comes off the Incident table. If "Survey Required" is true, we send a notification off of the Assessment Instance table. Because the Assessment Instance has "Trigger ID" (a field that contains the sys_id of the record calling it), we use a Mail Script to lookup the associated Incident or RITM information based on the sys_id. We then send out a "Your Incident has been resolved" email similar to above, however it is from the Assessment Instance table. We include our survey specific information in it (we use some cool graphics to entice them to click on the survey) and the Incident/Task information, which is obtained through the mail script.
3) Client takes the survey, we then do a custom table to transform the results into a format that is much easier for management to handle (a table where each row contains the questions/answers, rather than the ServiceNow format of each row being a question). We have some reporting we need to do based on the results of a specific question, and this kept it the "prettiest" for management and the most functional for our user base. The table just updates upon a survey changing to "Complete". Because we have the "Trigger ID" value (which again is the sys_id of the incident/task that called it), we can reference who the analyst was that did the ticket, the business service, etc.
Just in case anything does not make sense, I have attached a screenshot of our survey invitation email. It is run off the Assessment Instance table. While we do not show the CI/Business Service/etc., I think the other fields we pull demonstrate that we can pull those fields too.
If you have any further questions, feel free to post them. Or send me a message privately/email me and I can go into it further. We personally found the new Assessment module a bit overwhelming at first and it took longer than expected to develop it into something usable. But I think our stats are at a 12% response rate, so we must be doing a good job (our research department indicates this is a good response rate for unsolicited electronic surveys).
My apologies - I realize this is a bit long but I was unsure where exactly you were looking for feedback.
43 REPLIES 43
johnnyd54
Giga Expert
We're currently using both legacy and assessments. We originally had to separate them because we are sending surveys from projects to users who don't necessarily have access to the portal. They were created for the sole purpose of notifications and contact info.   Assessments at the time could not be taken by people who didn't have logins. I believe that may have recently changed.
Any way when it comes to reporting aspects we are using two homepages. One is very high level and is based on one question, our net promoter question. We're leveraging Performance Analytics to display the stats for our net promoter score over certain time periods. Using breakdowns we're able to see our scores for different assignment groups, regions, etc. Our other homepage is what we use for reporting on other questions as well as our process regarding following up on surveys that meet our conditions for follow ups.
HI there is a survey enhancement on the ideal portal would be good if you can vote on this as this wil address these issues and improve how the reporting would work.
https://community.servicenow.com/community?id=view_idea&sysparm_idea_id=4d4041b71b29cc107a5933f2cd4b...
Title: List Report on Survey Results in a Column
Stacey F1
The most straightforward way I have found to report survey results that captures the assignment group/assigned to, ticket # that the survey was triggered from is to write a report from the Metric Result [asmt_metric_result] table.
Filters:
  • Metric Type = Survey name
  • Instance State = Complete
Columns:
  • Instance
  • Metric.Category
  • Assigned to
  • Question
  • String Value
  • Actual Value
  • Updated
  • Instance.Task.Assignment Group
  • Instance.Task
I am trying to get report on the Metric Result [asmt_metric_result] table,
where I want the report on rating given to an Engineer(Assigned_to) in a month.
I want to add filters but unable to get it,
can you help me out?Thanks in advance.
