06-08-2026 01:46 AM
Hi all,
when I open enhancement table, in the list view I can see the sys id of the product instead of display name. I have attached the screenshot. How do I fix this?
06-08-2026 02:35 AM
Hi @maboopathi
1) The field pointing to the product might not have a primary display value assigned in the dictionary.
- Navigate to the table that holds the product information (in Your target table i.e enhanceent).
- Right-click the field label on the form and select Personalize Dictionary.
- Check the Display box so that it is set to true. (Note: Only one field per table can have the Display flag set to true).
- Save the record
2) If the display name works on the form but shows as a sys_id in the lookup list, you will need to modify the view specifically assigned to references.
- In the application navigator, search for and select System UI > Views.
- Search for and select the view named sys_ref_list.
- Under the Lists tab, find and open the record for your table.
- Under related lists, find List Elements and edit/add the fields you want to display
3) Clear the instance cache by typing cache.do in your application navigator filter and enter
06-08-2026 02:35 AM
Hi @maboopathi
- Save the record
