SYS Is not in query ?
sukran
In Server side background script how to query glide record ... Sys Id is not ..
Below query is not working
var rec = incident.sys_id ( stored incident sysid records)
addQuery('sys_id , '!=', rec);
ANY IDEA
James Chun
Hi @sukran,
Use the following query instead:
addEncodedQuery('sys_idNOT IN'+rec);
I am assuming the 'rec' variable is an array which stores the sys_ids.
Cheers
11 REPLIES 11
AshishKM
Refer the other's reply, you can update the addQuery() as below.
addQuery('sys_id' , '!=', rec);
-Thanks,
AshishKM
Mark Roethof
And do post more of your script. Now we cannot assist in if you actually made a different error. What you shared now, should be fine. Though apparently its not 🙂
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
