Tables and columns metadata
egidiocaprino
Hello.
Do you know anyway we can retrieve tables and columns metadata through the REST APIs? What we need is a list of existing tables and, for each table a list of columns with name and type.
sys_dictionary table should contains information about the columns but the labels are not human readable. I think I need to join another table but I cannot find any. Maybe sys_documentation but I cannot find the join field.
Can you please help us?
Thank you,
Egidio
The column should be "name" with label as "Table". This holds the table to which the dictionary entry is linked.
9 REPLIES 9
Hi Egidio,
I see a field "element" with label "column name" on sys_dictionary.
You might not see this for the sys_dictionary records which say type as   "collection" which represent the dictionary of the table it self. Here the column name will be empty. if this is not helping, please share a screenshot of what you are seeing. Will be easy to understand.
Chandana
You're right. The element is the API name of the column. Thank you!
The last thing I need is matching the table with the column. Is there any field indicating the table in the sys_dictionary table?
With this API call I'm getting all the columns named short_description: https://cloudreachdev.service-now.com/api/now/table/sys_dictionary?element=short_description
How can I detect from which table each column belongs?
Thank you for you help!
Egidio
Perfect! Thank you very much Chandana.
Hi Chandana,
I have a similar issue and have gone through this post but couldn't get the answer. I am using sys_dictionary table to get a list of all the tables. Below is a sample response of "sys_dictionary" for one table which I have created:
          "calculation": "(function calculatedFieldValue(current) {\n\n\t// Add your code here\n\treturn '';   // return the calculated value\n\n})(current);",
          "sys_replace_on_upgrade": "false",
          "dynamic_ref_qual": "",
          "choice_field": "",
          "sys_updated_on": "2017-05-02 06:16:54",
          "spell_check": "false",
          "reference_cascade_rule": "",
          "reference": "",
          "sys_updated_by": "admin",
          "read_only": "false",
          "sys_created_on": "2017-05-02 06:16:54",
          "element_reference": "false",
          "sys_name": "id",
          "reference_key": "",
          "reference_qual_condition": "",
          "xml_view": "false",
          "dependent": "",
          "internal_type": {
              "link": "https://dev13196.service-now.com/api/now/table/sys_glide_object?name=string",
              "value": "string"
          "sys_created_by": "admin",
          "element": "u_id",
          "max_length": "40",
          "use_dependent_field": "false",
          "delete_roles": "",
          "active": "true",
          "choice_table": "",
          "foreign_database": "",
          "sys_update_name": "sys_dictionary_u_tibco_u_id",
          "unique": "false",
          "name": "u_tibco",
          "dependent_on_field": "",
          "dynamic_creation": "false",
          "primary": "false",
          "sys_policy": "",
          "next_element": "",
          "virtual": "false",
          "widget": "",
          "use_dynamic_default": "false",
          "sizeclass": "",
          "mandatory": "false",
          "sys_class_name": "sys_dictionary",
          "dynamic_default_value": "",
          "sys_id": "3a4b70604f2232002fbce9628110c735",
          "write_roles": "",
          "array": "false",
          "audit": "false",
          "read_roles": "",
          "sys_scope": {
              "link": "https://dev13196.service-now.com/api/now/table/sys_scope/global",
              "value": "global"
          "create_roles": "",
          "dynamic_creation_script": "",
          "defaultsort": "",
          "column_label": "id",
          "comments": "",
          "use_reference_qualifier": "simple",
          "display": "false",
          "reference_floats": "false",
          "sys_mod_count": "0",
          "default_value": "",
          "staged": "false",
          "reference_type": "",
          "sys_package": {
              "link": "https://dev13196.service-now.com/api/now/table/sys_package/global",
              "value": "global"
          "attributes": "",
          "choice": "",
          "reference_qual": "",
          "sys_customer_update": "true",
          "table_reference": "false",
          "text_index": "false"
Here, the "name" attribute with value "name":"u_tibco", is representing the table name. But how do I get the column names ( column labels) of this corresponding table? I see a field "column_label" but it has only one value "id". I also have a column "name" in this table which is not shown here.
Below is the screenshot of the table:
Thank you in advance!!!
