To add a new approval in problem flow
pg6430
I need to add an approval level for Root cause analysis in problem how to to that and based on that the sla will be paused and the state will be pending. I am unable to find a workflow for problem in workflow editor and anything related to this. Please provide your suggestion.
Thanks already.
#problem
Dr Atul G- LNG
Hi @pg6430
There is NO OOTB flow/workflow on problem table. You need to create from scratch. But why you want mix SLA and approval mate.
Mark Tuffey
We are looking for the same type of process. Once the fix is offered we want at least two approvers from a management group before the fix can be applied. Did you find a solution to your original question?
