05-25-2020 10:33 AM
I am running Transform map to insert and update user records. Data source is a csv zipped file. My logic is not working when i am checking for trailer in the source.
Requirement is:
1.If the source field does not have trailer information (as in the attachment) the transaction should get aborted that is the transform map should not happen.
2.If the record count from source does not match the record count in the transform map table the transaction should be aborted.
05-29-2020 05:43 AM
Hi Lavanya,
here is the script; I tried in onStart transform script but somehow it didn't work out.
It worked well when added in onBefore transform script
script below
Note: Ensure you give proper
1) import set table name; I have used u_testing_data_load_csv
2) correct import set field name; -> u_recordcount and u_h
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
// Add your code here
var trailerCharacter = '';
var recordCountField;
var gr1 = new GlideRecord('u_testing_data_load_csv');
gr1.orderByDesc('sys_import_row');
gr1.addQuery('sys_import_set', source.sys_import_set);
gr1.query();
if(gr1.next()){
recordCountField = gr1.u_recordcount;
trailerCharacter = gr1.u_h;
if(trailerCharacter != 'T'){
log.error('Missing trailer row as the character T cannot be found in column H');
error = true;
else{
// found the tralier row now check whether the count of rows is same as record count column
var gr = new GlideRecord('sys_import_set_row');
gr.addQuery('sys_import_set', source.sys_import_set);
var totalRowsIncludingTrailer = gr.getRowCount();
var actualDataRows = totalRowsIncludingTrailer - 1;
if(actualDataRows != recordCountField){
log.info('Total rows are not matching hence setting error as true and it would halt entire transformation');
ignore = true;
error = true;
else{
// allow transform to run
})(source, map, log, target);
05-28-2020 03:28 AM
Is there any update on this? Is this question resolved or you need some more assistance.
05-28-2020 06:04 AM
Hi Ankur,
I am still looking for resolution.
