Transform map, skip record rather than ignore
Options
06-15-2020 02:00 AM
16 REPLIES 16
Options
06-15-2020 07:03 AM
Can you unchecked the run business rule and try.
As I wan't everything is inclined to the things which I did in PDI.
If not works then can you check is there any customization in your instance related to the the Business rule in the import set row table.
Any Business rule is added or done some other customization which is updated. You can click on the versions tab of business rule.
CB
Options
06-15-2020 08:08 AM
