Trying to figure sum calculation for variable values
Cheri M
I am trying to build a catalog item that is based on a spreadsheet that used the =sum calculation.   I've found a few ideas out there but nothing that will work for me.   We'd like it to be just for this catalog item so not a business rule.   Currently I have 5 columns, 1st   year — 5th year and we'd like each column to show the total at the end (a total cost of ownership).   Please see screenshot.   I got the fields figured out, now I just need a formula.   We'd like the user to be able to see the change as they did with the spreadsheet and not have the sum just sent in the form. I will make the TCO (bottom) row read-only if I get this all figured out.
Thank you!
14 REPLIES 14
I'm adding the columns, not the rows. Also I should have added I'm not very good with scripts which is why I was asking for help... so this is confusing to me when you are saying add the rows.   I need the costs for the first year, then the second year, etc. and there is a totals field at the bottom in the screenshot (Total Cost of Ownership).
If you see how I made the fields it's a HUGE mess of variables.   It's 13 variables to make one row.   There are 10 rows, no actual columns.   It just gets messy and confusing when I then have to add calculations into the mix.
I appreciate everyone's help!
And that is why I was saying to name the variables based on how they display to the user.   So
row_1_year_1
row_1_year_2
row_1_year_3
row_2_year_1
row_2_year_2
row_2_year_3
Then when you go thru a loop you now can predict what to add.   i.e. row_1_year_1 + row_2_year_1 + ....
Does that make sense?
I attached a pic of what I am saying.
Yes, that does.   Thank you.   I know it's me that is confused and not you!   I will give that a try.   I'll let you know how it goes.
I got all of the variables renamed.   I'm having an issue with the script (again the script is my weak spot - I am new in this postion so still learning).   I don't know what I might need to change to make it work for me and I'm also trying to understand the script itself.   I have row_1_year_1 through row_12_year_1 - 12 being the total field.   What needs to be added as you punch in the figures are all row (1-11) for year 1.   Then row_1_year_2 adding to total field row_12_year_2, etc.
When I use the script I get these two errors:
JavaScript parse error at line (3) column (13) problem = identifier is a reserved word
WARNING at line 2: 'total' is already defined.
ERROR at line 3: Expected ';' and instead saw 'y'.
Also am I adding this as OnCellEdit   ?
Thanks again.
Please post your script.   Also this needs to be an onChange script for all of the boxes that the user will type in.
