UI policy is not working in making the "assigned to" field on "problem" form to Mandatory. Could you plz help on this resolving this .
anil4005
UI policy is not working in making the "assigned to" field on "problem" form  to Mandatory. Could you plz help on this resolving this , Below is the ui policy Andalso i have increased to highest order for that ui polocy.
There is a Data Policy OOB which is restricting this to happen.
navigate to the below link :
https://instance.service-now.com/nav_to.do?uri=sys_data_policy2.do?sys_id=9f1b086f875b13000e3dd61e36cb0beb
Replace "instance' with your instance name.
Select the New state value as well along with other state as shown below and you should be good here:
Result:
Shloke
17 REPLIES 17
Nice Catch.
I was suppose to search
Thanks Shloke, it is working fine.
I have a similar requirement in this, Instead of Assigned to I want keep assignment group as mandatory in the pop up.
Because if I select the assigned to then in assess phase I am keeping assignment group as mandatory since assigned to is dependent on assignment group, once I map the assignment group assigned to is getting removed.
Can someone help how to add assignment group in that pop up which is coming once you click on assess button?
