UI policy is not working
ANWAR BASHA
i create one UI policy in that i added some filter conditions like.
State is one of high, critical,
And
Assignment group. name  does not contains HIK
And
caller is not Sam
or
caller is not RIck.
caller field is reference field from sys_user table.
order of the UI policy also correct.
i using the above conditions but UI policy is not working can any one help on this how to archive this.
Weird
Your conditions must always be AND if you don't want either user to match.
So, change the OR between the callers to AND.
Now you're saying OR so if you select Rick, then caller is not Sam and it evaluates to true.
If you change it to AND caller is not Rick, then it checks that Caller is Rick, but not Sam, but since AND requires both to be true, the condition will fail.
Weird
ANWAR BASHA
Hi Joni,
Now changed the all conditions as per AND conditions it is working fine now.
Thank you!
