UI Policy Not Working on Existing Records
ddiroma
Mega Expert
I have a UI Policy that based on the selection of field a (Caused by Third Party) should show and make mandatory field b (u_third_party_name) within a problem record. This seems to work fine if it is a new record, but doesn't work at all on existing records. We just upgraded to San Diego. This is my first UI policy in San Diego. Any idea if I am doing something wrong or if this is a bug? I have done countless UI Policies this way, but maybe I am missing something.
ddiroma
Mega Expert
Looking at the dictionary history of the caused by third party field it seems as if someone changed the field type from a true/false checkbox to a choice list with True false. Although the records where the UI policy do not work were set after that field was changed, I am going to assume this has something to do with it. I am going to speak with the stakeholders, but I am guessing that I will end up creating a new field, passing the data, and deleting the old field. That is unless someone has a better idea/solution?
ddiroma
Mega Expert
After creating a new field this worked, so it appears to be related to the change in the dictionary.
