Unable to convert sys_id into Names. Help!!!
Pankhil
Current codes works and returns
When the line in orange is enabled.
But the underlying function does run Scripts-Background.
var access = g_form.getReference('access_level', getAccess);
function getAccess(access)
g_form.setValue('time_spec_group',access.time_spec_group);
//g_form.setValue('access_approver',getApprovers(access.access_approvers));
g_form.setValue('access_approver', access.access_approvers);
function getApprovers(List){
var outString = [];
for(i=0;i < List.length; i++)
var user = new GlideRecord('sys_user');
if(user.get(List[i]))
var username = user.name;
outString.push(username);
return outString;
Pankhil
Ended up going with GlideAjax
Script Include
Catalog Client Script
Glad, you implemented this using glide ajax.
@Pankhil
Do you need any further help on this?
If your query has solved, Kindly mark the answer correct and close this thread.
