Update variables using PUT/PATCH method in RITM from third party
Bijender
We got the record created vis POST method , but now need to update the variable of existing RITM.
Tried some method shared in community and created a Scripted REST API, but seems I am doing something wrong as it is not working.
Please advise.
Script REST API created:
Error:
B
SANDEEP28
@Bijender You are mentioning RITM number in relative path and in the script you are trying to fetch it from query parameter which is wrong. You need to fetch it from path parameter. Follow below steps
1) Put the below script in script section
(function process(/*RESTAPIRequest*/ request, /*RESTAPIResponse*/ response) {
var ritmNumber = request.pathParams.number;
var reqBody = request.body.data;
if (ritmNumber) {
var bodyObject = JSON.stringify(reqBody);
var parser = JSON.parse(bodyObject);
var variables = parser.variables;         // get the variables data
var variablesObject = JSON.stringify(variables);
var variableElements = JSON.parse(variablesObject); //parse variables data
var ritmObj = new GlideRecord('sc_req_item');
if (ritmObj.get('number', ritmNumber))
gs.info(ritmObj.ritmNumber);
ritmObj.variables.new_email = variableElements.new_email;
var recordUpdated = ritmObj.update();
if (recordUpdated)
var body = {};
body.status = 'record successfully updated';
response.setBody(body);             // set the response body
})(request, response);
2) As you are already passing the number in path parameter the no need pass again in the request body. Sample request body as below
variables: {
"new_email": "servicenow12345@gmail.com"
11 REPLIES 11
Strange...
It looks like somehow postman is sneding a get, instead of a put. Doesn't seem to be a ServiceNow issue.
Does it work when you use Rest API Explorer within ServiceNow?
Help others to find a correct solution by marking the appropriate response as accepted solution and helpful.
Hi Peter,
When I use REST API Explorer within service-now  it gives me 200 success but response body as blank.
Hi @Bijender,
Thats good, so the first issue is something within Postman, can't really help with that.
You are not getting a response because you haven't defined that in the Script.
Use something like this:
var bodyArray = [];
var body = {};
body.name = "incident";
body.number = "1234";
body.caller = {"id":"user1"};
bodyArray.push(body);
response.setBody(bodyArray);
SANDEEP28
if (ritmNumber) {
if (recordUpdated)
var body = {};
variables: {
SANDEEP28
@Bijender If I could help you with your Query then, please hit the Thumb Icon and mark as Correct !!
