Users should not be able to approve their own requests
AparnaUttaG
Hello Team,
Can anyone suggest how to achieve this requirement?
If the approver = created by user(Requested for) then they should not be able to approve the request.
Here is a BR that I think will do the job.
Condition: current.source_table  ==  'sc_req_item' && current.sysapproval.opened_by ==  current.approver
Script:
	// Add your code here
	current.approver = current.approver.manager;
	current.comments = 'Approver is also Requester - Moved to Manager';
})(current, previous);
It was modified from a BR that I've used to auto-approved if Requester is also Approver. I haven't tested it.
Niklas
Vishal Birajdar
Hi @AparnaUttaG
You can divert the process in workflow.
E.g.,
If requestor is itself an approvar then skip the approval activity else
Go to approval activity.
