Using RITM variables in workflow
Joe Taylor
Giga Guru
I have an catalog item with various variables.
Two of them are pulldowns of people in specific user groups.
Let's call the first pulldown variable:  user1   (user1 is in a group called "FirstGroup")
Let's call the second pulldown variable user2.  (user2 is in a group called "SecondGroup")
I want to make "user1" my approver in the workflow.
After the approval step, I want to create an SCTASK and assign it to Group "SecondGroup" and also specifically to "user2".
What's the best way to do this in my workflow?
use below for dynamic
answer = [];
answer.push(current.variables.hrbp.toString());
For task
Is your hrbp variables a reference field ? can you share screenshot?
aslo try
task.setDisplayValue('assignment_group', 'HRD Group');
task.assigned_to = current.variables.hrd.toString();
12 REPLIES 12
If nothing works, can you try
answer=current.variables.hrbp+'';
and in task script
task.assignment_group.setDisplayValue('HRD Group');
task.assigned_to = current.variables.hrd+'';
Sanjiv,
This syntax is not being accepted.
Are you sure you want me to put in the characters:  +"; at the end?
Adding a '' convert the value to string. But good that you got a solution.
