Using TAGS in a flow
BrianS344076034
We are trying to sort out software entitlements, but its backlogged right now.
A quick solution that was proposed was adding TAGS to the Users record for some of these things.
Example
User is entitled to Adobe Acrobat
once the request is fulfilled, I want to add the TAG Adobe Acrobat to the Users record.
I tried the following in the flow designer
Update Record - sys_user table
Tag - Adobe Acrobat
When I run the test it works, but when I go to the users record, the tag is not there.
Any ideas?
Ultimately we want to show the user was entitled to Adobe, but I have to get to it still.
Viraj Hudlikar
Tera Sage
Hello @BrianS344076034
Adding only tag to record won't work as its only half process you are doing from your flow. When normal a tag is added to record an entry is made over table Tags [label] and associated record which is tag a entry is made over Label Entries [label_entry] table so if you are going to add tag from flow you will need to make entries in both tables.
Check below thread where it was similar requirement.
Solved: Flow: Add tag to catalog task & find that tag in c... - ServiceNow Community
Check this video for more details on tags
https://youtu.be/94G-W1WRi0U?si=2h3vNFlMdteFbk1a
Thanks & Regards
Viraj Hudlikar.
