Variable Read Only
Bishal Sharma
Can you help me to make below particular variable read only when state is closed complete or closed incomplete or closed skipped. (screenshot attached)
shloke04
Hi @Bishal Sharma
This can be done using a Client Script on Catalog Task Table. You just need to write an On Change Client Script on Catalog Task Table on State Field and use the script below:
This client script will take care of both scenario when state changes also after you save the form it will validate for the state value to make it read only.
Script:
        var getState = g_form.getValue('state');
        if (getState == 3 || getState == 4 || getState == 7) {
            g_form.setReadOnly('variables.checkbox', true);
    if (newValue == 3 || newValue == 4 || newValue == 7) {
Screenshot for reference:
Result:
Script is an tested one in my PDI and will work for you as well for the query mentioned.
Shloke
Shloke
Hi @shloke04 ,
Thanks! this actually worked as expected.
I have marked your response helpful and correct too.
Have a great year ahead!
