12-26-2025 07:09 AM
When we click on complete button on the problem task record, there is a popup that appears and i want to add one more field into that popup. not sure where and how to find its configuration.
Below is the Popup which is OOB functionality. I need to add one more field into it. please help me where to find this and add
Thanks in advance😀
12-26-2025 07:44 AM
Simply check form view on problem_task which is used to render the fields in popup
-> just add/remove the fields in that correct view and it will reflect in popup
-> see below and compare the correct view
12-26-2025 08:17 AM
workaround field
12-26-2025 08:21 AM
It's an OOTB field, so it should display. Please check if you have any custom UI Policies/Client scripts that make workaround field visible conditionally.
12-26-2025 08:25 AM
You can also validate if workaround field is always visible in the problem task or is it conditionally displayed. OOTB, there are no specific conditions that I am aware of.
12-26-2025 08:24 PM
check if some UI policy or client script is hiding that field from that view
If it's on form view then it should show unless somebody is hiding
12-26-2025 08:21 AM
Hi @Mk_snow ,
I tried your problem in my PDI and it works for me
I navigate to All< System UI< Views
Search for the view name "ptask_complete_dialog_view_1"
Open the record and in related list called "Form Section" open the record by clicking the i icon
In related list by clicking new I added one element called description
Note : Please do cache.do and hard refresh (Control + Shift + R)
Link for reference
yourInstance.service-now.com/sys_ui_section.do?sysparm_nostack=true&sys_id=71514d55870123000e3dd61e36cb0b64&sysparm_view=&sysparm_record_target=sys_ui_section&sysparm_record_row=1&sysparm_record_list=view%3Db5510d55870123000e3dd61e36cb0b27%5EORDERBYname&sysparm_record_rows=1
Result
Please mark my answer correct and helpful if this works for you
Thanks and Regards,
Sarthak
