‎12-27-2024 04:16 AM
Hi Team,
I want to make few checkboxes label in red color in my catalog item in portal...I tried g_form.getControl method in client script but its not working does anybody have any idea how to do that please help me? Thanks
‎12-27-2024 04:27 AM
g_form.getControl() won't work in portal.
check this link where I shared solution few years ago and it works in both native + portal
How to make text of Label type in Bold
Sharing sample script from same here again
You can use this catalog client script onLoad and make the Label variable as Bold
Script: This will work in both native + portal
1) Ensure Isolate Script field is set to false for this client script
2) This field is not on form but from list you can make it false
function onLoad(){
setTimeout(function(){
if(window != null){
// native
g_form.getControl('variableName').setAttribute('style', 'font-weight: bold;color:blue');
else{
// portal
var aTags = this.document.getElementsByClassName("ng-binding");
var searchText = "My Label"; // give the label name here
var found;
for (var i = 0; i < aTags.length; i++) {
if (aTags[i].textContent.toString() == searchText) {
aTags[i].style.fontWeight = 'bold';
break;
}, 3000);
Output:
Native:
Portal:
‎12-27-2024 05:39 AM
did you give correct variable name?
please share your script, client script screenshots and screenshot for variable configuration
Any browser console error when it runs in RITM view?
‎12-27-2024 05:47 AM
‎12-27-2024 05:56 AM
so Workday should be in bold and red?
it's a checkbox type then the script I shared for native won't work, it will change the label as bold and red and not the checkbox value
use this and it will work for native
$j("label:contains('Workday')").css('color','red');
$j("label:contains('Workday')").css('font-weight','bold');
‎12-27-2024 05:49 AM
Showing this in client script as well
‎12-27-2024 06:05 AM
when you make Isolate Script Field = False then the above should work fine
that's just a info message for DOM
you are in global scope or scoped app?
