What is coalesce checkbox and How it execute
kpathak1803
What is coalesce checkbox and How it execute?
Please do let me know.
Thank you!
2 ACCEPTED SOLUTIONS
G Ponsekar
Hi @kpathak1803 ,
Coalesce is a feature in ServiceNow that determines if a row in a staging table matches a record in a target table. It can be used to prevent duplicate data and update existing records instead of creating new ones.
Coalesce is like unique key, if match found then update else create a new record
Thanks, GP
Juhi Poddar
Hello @kpathak1803
  • In Transform Maps (used during data imports in ServiceNow), the Coalesce checkbox determines how records are matched between the Import Set table and the target table.
  • It tells ServiceNow to use that field to find an existing record in the target table. If a match is found, the existing record is updated. If not, a new record is created.
  • You can coalesce on more than one field (e.g., First Name + Last Name) to make sure you're updating the right record.
The following post and article can be helpful:
Hope this helps!
"If you found my answer helpful, please like and mark it as an "accepted solution". It helps future readers to locate the solution easily and supports the community!"
Thank You
Juhi Poddar
9 REPLIES 9
shyamkumars
@kpathak1803  -
Coalesce is commonly used with Transform maps in ServiceNow. It is used to set a field as unique , this will avoid Duplication during the Import
For more context refer to following , this below link response helps you to understand more on the Topic
https://developer.servicenow.com/dev.do#!/learn/learning-plans/xanadu/servicenow_administrator/app_s...
https://www.servicenow.com/community/itsm-forum/what-is-coalesce-explain-with-example/td-p/2341075
Dr Atul - LNG
Hi @kpathak1803
https://youtu.be/f5DCq8GJ3pQ
https://youtu.be/vKIQ1IZDP10
My tutorial will be helpful here.
csa #ServiceNow #TechnoFuncational Disclaimer: These videos are from my training batch. These videos did not promote any ServiceNow Sales pitch or marketing. These videos are only for knowledge purposes based on my experience and knowledge. Redistribution or copying of functionality is not ...
glideFather
Hi @kpathak1803,
you got definition in parallel answers or you can simply google it but let me give you a real use case:
For the user management a client has LDAP (user database with all their details - name, email, location, position, department, whatever) and ServiceNow for their ITSM.
LDAP and ServiceNow are two different systems, so when you want to keep the data 1:1 in both sides, you need to integrate and sync between them. And because user ID in LDAP is different than user ID in ServiceNow as well as sys ids, so for that there is a coalesce.
When LDAP is sending data towards ServiceNow there might be two people with the same name (John Doe) to be sure that the data are not mixed, there is a coalesce field that will determine whether it is the same record based on same unique identifier (usually email).
  • LDAP sending data to ServiceNow - check for the email and email in LDAP is equal to email in ServiceNow thus the rest of the data are used to update, if there is no change, nothing happens.
  • LDAP sending data to ServiceNow - check for the email and this email doesn 't exist in ServiceNow, so a new user will be created.
Let me know if this simplified example makes sense to you
_Tushar Soni
Hi @kpathak1803 ,
What is the Coalesce Checkbox in ServiceNow?
-- The Coalesce checkbox is used in Transform Maps when importing data into ServiceNow. It helps the system decide whether to update an existing record or create a new one.
How Does It Work?
When you mark a field as Coalesce, ServiceNow checks if a record in the target table already exists with the same value in that field:
✅If a match is found → the existing record is updated.
❌If no match is found → a new record is created.
This helps avoid duplicate records and keeps your data clean.
Example:
Let’s say you’re importing user data and you mark the Email field as coalesce:
If a user with that email already exists → their record will be updated.
If not → a new user record will be created.
If you found my response helpful, please consider marking it as "Helpful" or "Accept Solution." Thank you!
