What is the use of Variable Validation Regex and how to use it? w.r.t. Madrid
Maloy Banerjee
Mega Expert
Can anyone put some light on the topic "Variable Validation Regex" on what's its use and why it's been used?
It is a new topic in Madrid under:
Service Catalog > Catalog Variables > Variable Validation Regex.
Please suggest.
Many Thanks,
Maloy
SatheeshKumar
It is new and great feautre added in Madrid,
Instead of creating repeated validation scripts, we can create a variable validation regex and use it in our variables.
steps to use:
step 1: create variable validation regex
step 2: open your variable dictionary, configure your form layout to add "Validation Regex" in form
step 3 : choose the validation regex which you want apply for the variable and save
step 4:  now test the variable by entering your input, it will throw error message ,if the entered input doesn't match the Regex
this will save a lot of time and effort which will be spent for creating same validation for multiple variables.
-Satheesh
Hi Satheesh,
i am using this for my validation and i'm using regex to filter certain numbers, however, if i enter any thing other than numbers i get "NaN" error in the string field , i was wondering if you've any insight to stop this from happening?
Varun Sharma
